| Uncore Frequency can be set
ranging from 1600Ghz to 4266MHz. |
Memory frequency operating at
a ratio to the BCLK can be set ranging from DDR3-800 to DDR3-2133 |
| CPU voltage can be upped to
1.60v |
DRAM Voltage can be upped to
2.451v. It is advisable not to exceed 1.6v. So use anything beyond 1.6v with
extra cooling and care. |
| DRAM Ctrl Ref voltage can be
increase by up to +0.08v |
DRAM Data ref voltage can be
increased by up to +0.08v |
| IOH voltage options ranges
from 1.11v to 1.49v |
For oc stability, VTT offset
can be upped by +300mv |
| ICH voltage, IOH CSI voltage
and IOH/ICH PCIe voltage can be maximised to 1.56v, 1.56v and 1.90v
respectively. CPU Pll can be increased to 2.50v |
