ECS X58B-A Intel X58+ICH10R Intel Core i7 Mainboard Review - BIOS Screen shots
Bluetooth 6 March 2009
BIOS 2
The screen shots are taken with board installed with a Intel Core
i7 965
| DRAM Frequency can be set to
run from 800MHz, 1066MHz, 1333MHz or 1600MHz. If you enable XMP profile, it
will be able to run according to what the RAM specifies. |
South bridge voltage can be
increased up by +0.945v |
| Uncore Ratio or Frequency can
be set from auto to 2666 ~ 4000MHz as seen in the screen shot above. |
Ram timings can be set
manually for CAS, trd, trp, trcd and dram cmd rate or 1T or 2T. |
