Detail Specifications and 3DMark Vantage Benchmark of Gigabyte
N295-18I-B NVIDIA 295 GTX Graphics card
Introduction
The card is tested on a Intel Core i7 Extreme 965 running at 3.2GHz,
GA-EX58-Extreme with DDR3-1066 (2GB). Cat 8.12 is used on ATi card and Forceware
180.84 is used on NVIDIA cards.
From the chart, we can see that the N95-18I-B leads the R487X2-2GH-B with a
score of 9080 vs 7343 running on the same machine. That is a 23% performance
difference between the two high end cards.
So, would you get it ? Discuss in the forum at the graphics card section.
