Samsung
UltraTouch S8300 8 mega pixel camera phone
user Interface
OCWorkbench 22 Apr 2009
Samsung UltraTouch
S8300
The main interface looks very similar to the Pixon M8800 and
the Omnia. it has a
sidebar that is where all the widgets are located. You can drag and drop the
widgets to the desktop or scroll the list of widgets.
On the desktop itself are 4 main menus "Keypad, Phonebook,
Menu". With a touch, it brings you to the submenus for more
options. See video on next page for options available.
Below is a picture of the phone with the keyboard slide out.
In fact, the phone can be used without the keypad. By default, you can use the
touch screen to make calls thru the keypad or phone book button on screen. You
can select to lock the touch screen from the options in the phone so that you
won't accidentally make a call unless you slide out the keypad.
The Phone Pad
Discuss >>>
