Software Tech Support Discuss about the latest software problems including antivirus, anti malware programs. Troubleshooting program errors. |
Future MRT MAP has MOVED here. Click here.
SHARE
Windows 8.1 update stops RT staring up Software Tech Support
21-10-2013, 07:50 PM
The one
Potenza rep: 10
Windows 8.1 update glitch stops RT starting up
Microsoft cut the price of its Surface computers in a bid to boost sales
Continue reading the main story
Related Stories
Windows 8.1 gets global release
Dell tablets shun Windows RT system
Coders get early look at Windows 8.1
The latest Windows update is causing problems for owners of Microsoft's Surface RT gadgets.
The Windows 8.1 update has reportedly meant some of the touchscreen devices will not start up properly.
Microsoft has removed the update from its website while it looks into what has caused the problems.
At the same time, many people are reporting that the 8.1 update for Internet Explorer does not work well with Outlook and some Google services.
Recovery effort
Soon after the update's global release, on 17 October, Microsoft started to receive reports that once it had been applied to RT tablets and laptops, the gadgets had frozen during the boot-up process.
Windows RT is the version of Microsoft's operating system built to work with mobile and portable devices that use Arm chips. By contrast, other version of Windows run on machines that use processors from Intel or AMD.
Soon after the problems were reported, Microsoft pulled Windows RT 8.1 from its update site.
The update was pulled while it was "investigating a situation affecting a limited number of users", it explained in a support forum response. It added that it was working on a fix for the problem it had caused.
Prior to the official release, Windows RT user Scott Williams found a way to help people with tablets crippled by the update. Mr Williams created a start-up drive with a USB stick that helped bring stricken RT gadgets back to life.
Squashed search
The version of Internet Explorer 11 that ships with Windows 8.1 update has also caused problems for many people.
The updated version of the web browser has caused Google search results to be mashed together at the left hand side of a display. Others have reported IE11 has caused similar usability problems with Google's Play website and Music service.
In a statement, Microsoft said changes Google had made to its search and other sites were responsible for the glitches. Despite this, Microsoft has now made changes of its own to fix the problem, which can be turned on by unticking an option in IE11 that makes the browser use "Microsoft Compatibility lists".
Microsoft has also issued advice about how to get IE11 working with web-accessible versions of its Outlook email program that had become un-useable with the new version of the browser.
Source bbc news
22-10-2013, 12:17 PM
Silver Member
Potenza rep: 20
I did not like the sound of Compatbilty Lists when I installed 8.1, so I turned it off immediately. I have experienced no problems with IE 11, in fact it's faster than Chrome. I like IE again. :)
__________________
EVGA Z390 FTWIntel i7-8700 6 core 4.5G, 32G Corsair Vengeance[b]
Intel SSD6 M.2 2000G/Samsung 840 EVO PRO 1000G SSD; Corsair H100; NZXT Phantom 820; EVGA Supernova 1300
Gigabyte RTX 2080 Super / ROG Strix XG49VQ 4K curved (main 49")Win 11 Pro; Razor Black Widow Ultimate; 7.1 Bose/Rockville combo; Razor Orbweaver Gamepad; Oculus Rift S VR
Keep Tweaking!
22-10-2013, 12:44 PM
The one
Potenza rep: 10
Quote:
Did you upgrade from win 8 64 bits to win 8.1 64 bits?
23-10-2013, 10:42 AM
Silver Member
Potenza rep: 20
Quote:
Yes I did. Seems a bit snappier than 8.0
__________________
Keep Tweaking!
03-12-2013, 01:25 PM
The one
Potenza rep: 10
Is till couldn't find my Microsoft office application
03-12-2013, 02:15 PM
Silver Member
Potenza rep: 20
My wife's new surface tablet got 8.1 installed last night. I had to get 26 uipdates to RT before it would let me install 8.1. Some took forever, and one hung up as 10 hours later it was still installing. So I held down the power button and forced it off. Turned it back on, the update only took two minutes on the next restart.
Running very well now, oh and 20 more updates this morning.
__________________
Keep Tweaking!
03-12-2013, 02:34 PM
The one
Potenza rep: 10
That is insane. So many updates
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
