THE
CHIPSET HEATSINK MOD GUIDE
Updated 05/11/02 by Tim B @ OCWorkbench.com
Useful related threads.
http://www.ocworkbench.com/ocwbcgi/ultimatebb.cgi?ubb=get_topic&f=27&t=001975
http://www.ocworkbench.com/ocwbcgi/ultimatebb.cgi?ubb=get_topic&f=27&t=000398
This mod improve the
efficiency of the standard heatsink on the mobo. It helps when trying to
achieve high fsb�s and can improve stability. Note there is no chipset
temperature on the K7S5A, the board has the capacity for 3 but only two are
connected.
By OC_Ripper
It's easy. remove it by twisting the heatsink. The clean the sink and chipset
from all the leftbehinds. Now apply a thin layer of thermal paste (mostely
white). Remove a little bit on the corners (the edges dont need to be glued).
now put a little drop of superglue on the corners of the chipset. press the
heatsink onto it, within a few seconds you wont be able to get it back off. and
voila. you might consider afterwards of putting a fan ontop of the heatsink.
