THE PLL MOD GUIDE Updated 05/11/02 by Tim B @ OCWorkbench.com Original thread - highly
recommended read. ICS9248-199 Datasheet Courtesy of Miikka Kolo More pics here > http://www.saunalahti.fi/~kolo/hardware/K7S5A By Pegelius See this Wiring guide pic Ok, here is some
information conserning building this kind of mod. My english isn't, in most
cases, perfect, so ask if something bothers =). Note: some knowledge IS
required.With this mod you have to solder your mobo. So be warned... copy-paste of mail i send to Easychiller: Ok, i'll try to give some information: I used pll-chip from a 486 machine. U should use more advanced chip, if u want to have serial I/O and USB working (feed for 24 Mhz and 48 Mhz). Modern mobos have those, so broken mobo is good. First you find the pll-chip. It's near crystal. Most of the time manufacturer is called ICS or Cypress. Datasheets can be found from their websites ( www.icst.com and www.cypress.com ). If you don't find datasheets, find another mobo (with different chip) :/. Next comes the fun part,
u get to brake things . Things to get: -some wire Next you have solder wires with resistor to TurboPLL's REF0, 24 output and 48 output. Find also VDD and GND. There goes power to the chip. Next thing is to find correct spots in the K7S5A where to connect those replacing signals. It is done by testing the continuity with voltage meter or something which shows if two spots are connected. REF0 (14.3)Mhz) leads to two resistor; other is pulldown (REF0 also works as input during boot), and other is the one to be removed (around 33 ohm). When removed, connect REF0 from Turbo to other spot where resistor was (the further one). 24 works same way, to resistors, othe pulldown (i guess, didn't measure thoroughly because didn't have those replacing signals in my Turbo). 48 is only output, so finding the resistor should be easy. Happy modding, ask if something bothers. PP
