| CPU Host
frequency can be set to AUTO or Manual. When set to Manual, you can adjust
it from 100 ~ 248 at 1MHz stepping. DRAM Frequency can be set to run at
200 for Sync (since i am using AXP3200+) or at 166,133,100. Flexibility
Option is disabled as this will reduce the performance for max
compatibility with different ram modules. |
Under the
chipset configuration, we set DRAM manually. ECLK you see here is the
Graphics core engine clk. There are available options of 133,166,200. We
tried 200 but it hung. 166 is OK.
DRAM CAS Latency is set to 2 |
