ULi
M1697 Ref Board Benchmarks 2
Benchmarks In this comparison, we compare the 6150K8MA-8EKRS against the ULi M1697 reference board. All tests are done using the Corsair TWINX memory running at CAS 2, 5-2-2, 1T. The Default Clock is still a valid and important criteria when judging systems performance. We measured the default clock and found that the ULI ref board runs at 201.9. In order to have a fairer comparison, we increased the Foxconn 6150 board to 202MHz. Using CPU-Z measures it as 202.1. The following readings are obtained using CPU-Z.
Using SiSoft Sandra Memory Benchmark, we measure the bandwidth when running at CAS 2, 5-2-2-1T. The results aren't that far off from each other.
