ECS
KA3 MVP Extreme AM2 board (ATi Xpress 3200) Review Benchmarks 1/8
Benchmarks In this test, we measured the CLK used by the boards. Both boards are set to run in SPD mode of the modules which is rated CAS 5, 5-5-15, 2T. The ECS KA3 MVP Extreme is based on the ATi RD580 chipset while the ASUS M2N32-SLI is based on NVidia's 590 SLI chipset. From the chart, we can see that the ASUS is slightly faster by 1/2 a MHz. Will that give it a lead against the ECS KA3 MVP? For a fair comparison, the auto overclocking features on both boards are switched off.
With that in mind, we take a look at the memory benchmark scores using Sandra 2007. The ECS KA3 MVP is leading by around 100 points. Does that translate to better benchmark results? We shall see.
