ECS NF650iSLIT-A (NVIDIA
650i) mainboard review - PCMark2005
Benchmarks PCmark2005 PCmark2005 tests a number of important items in today's computing world. File Compression, Encryption, Decryption, Audio Conversion, Web Page Rendering, WMV Video Compression, DivX Video Compression, Physics Calculation and 3D, Graphics Memory etc. With PCMark05, we see that the scores are a bit of different due to the different memory controller of the 3 different chipsets. The ECS NF650iSLIT-A score 7903. Although it is higher than most of the boards, it is behind the two 680i boards we tested. Again, we see that the score is highly determined by the CPU CLK. The ASUS in this case has an upper hand. Surprising, the ASRock 4CoreDual-VSTA based on the VIA did the best among the boards tested.
With the individual CPU test segment, we see that the results are not very far off. All the boards gives the CPU score ~ 8554.
