Gigabyte GA-X38-DQ6
Intel X38/ICH9R Mainboard Review 2/6
Gallery
At the bottom left corner you will see the coloured front panel connector. There are 6 SATAII connectors controlled by ICH9R, the other 2 is by the Gigabyte labelled Jmicron JMB363 chipset which controls 2 SATA and 1 IDE channel. On the back panel, you will find the PS/2 Keyboard and Mouse, S/PDIF digital and Coaxial out, 8 USB ports, 1 1394, 2 GbE and 7.1 ch audio ports. Additional USB ports and 1394 ports is provided via external brackets.
