Benchmarks -
3Dmark2005/3DMark2006
Paired with a ASUS EAH2600XT, the graphics
performance test is performed. Apparently, the difference between the difference
is noticeable. Gigabyte MA790FX-DQ6 based on the 790FX chipset leads the 770
chipset.
In comparison to the Intel Quad Core clocked at
2.3GHz, the two boards are not a match, lagging behind by around 200 points.
In 3Dmark06, the results shows a difference of
around 90 points when we compare both platforms. There is little performance
difference between the 790FX and 770 chipset.
We can see that the CPU/HDR/SM2 scores of QX6700
clock at 2.3GHz is generally higher. This resulted in a high final score.
Score |
SM2 |
HDR/SM3 |
CPU Score |
Gigabyte P35T-DQ6 (QX6700 at 230x10) |
4851 |
1625 |
1993 |
3297 |
Jetway 770 (Phenom GP-9600) |
4760 |
1600 |
1965 |
3107 |
Gigabyte MA790FX-DQ6 (Phenom GP-9600) |
4768 |
1600 |
1968 |
3133 |
