The is the main screen of the BIOS. it gives you a detail
look at the processor, bios version, ram used. |
ASRock now provides 5 default settings for BIOS. You can
run them using the default performance setup with IDE/SATA, AHCI or RAID
setting. A new option is the power saving setup default. So it saves you a
lot of time meddling with different settings. Just select, save and exit. |
In overclock mode, you can select the CPU:RAM to run in
SYNC or ASYNC mode or optimised mode. The CPU Freq ranges from 200 - 500 MHz
while the PCI ranges from 100 - 150MHz. |
Once you choose manual set up of the multiplier/ voltage
change, you can greeted with the above menu. You can choose the multiplier,
voltage here. The CPU voltage can be upped to 1.5626v. The same
applies for the North bridge voltage. |
