The DRAM Frequency can be set to operate in ASync mode of
200,266,333,400 or 533 MHz. Lower this value to restrict the RAM freq to run
at a ratio of the CPU CLK durig overclocking |
CAS Latency and RAM timing adjustmenets, CAS, tRCD, tRP,
tRTP, tRAS etc. cmd rate 1T/2T option is not available Other options are
Gang/Ungang mode for Phenom processors. HDMI Audio enable/disable option is
found here (should be group under other settings) |
In this page, you see a few options. First is the CPU
voltage, DIMM voltage adjustments. CPU overclock func (CPU Frequncy
adjustments) and GFX engine clk Override (which is GPU clk adjustments).
Over here CPU voltage can be offset by up to +252mV in addition to the
default voltage set udner AMD CPU FUNCTION |
DIMM voltage can be increased over here by up to +630mV.
In actual fact, the window allows us to set to a maximum of only 60. |
