Gigabyte GA-X48T-DQ6
Intel X48 chipset mainboard review - SiSoft
Sandra XII Benchmarks
The GA-X48T-DQ6 and GA-P35T-DQ6 are put to the test using SiSoft Sandra XII. From the chart, we tested the Arithmetic and multimedia performance of the CPU. The CPU used is a QX9770 which clocks at 3.2GHz (400 x 8). The board X48T-DQ6 is paired tested twice, paired with a 8600GTS and later a 8800GT.
We can see from the chart below that the results aren't that far off. In fact, we noticed something interesting. The P35T-DQ6 with the latest BIOS seems to perform slightly better. Looks like the F3C BIOS on the X48T-DQ6 isn't well optimised yet.
