ASRock M3A785GXH/128M
AMD 785G+SB710 Mainboard Review
SiSoft Sandra 2009 Benchmarks
The ASRock M3A785GXH/128M supports the ACC feature just like it's little brother the M3A785GMH/128M. Instead of explicitly naming the hidden feature as a patch, it just labels it as the normal ACC feature just like in the any AM3 boards. When the ACC is enabled, you can select per core or all cores for voltage boost. Once that is done, the hidden core on the Phenom II X3 710 appears. The first is the default timing with GPU running at 500MHz and side port memory at 667 MHz (DDR3-1333). The second test is with GPU overclocked to 980MHz with voltage bumped slightly to the mGPU voltage. 900MHz is only achievable on the mATX version M3A785GMH/128M.The third test is with the the 4th core enabled and in the fourth test, we increase the sideport memory to 790MHz or DDR3-1580. On the board, we ran two piece of three of the Kingston HyperX memory at C7-7-7-20-1T. This is in contrast to DDR2-1066 running at CAS 5-7-7-24-2T. From the chart, we can easily see that with DDR3, the memory bandwidth is slightly better at 11.8-12GB/s. As this is a memory bandwidth test, there is apparently not much difference in the score line whether it is a 3 core or 4 core. On a DDR2 board, it only scores around 11.6GB/s
Arithmetic Processor test With 4 core enabled, the increase in performance is noticeable. In Whetstone, the difference is 33% while Dhrystone gives a difference of 36%. As this is more of a test of the processor, the differences between a DDR3 vs a DDR2 board is very minute. The scores are almost identical.
Multimedia Processor test The improvement in Multimedia test is quite noticeable too. In Int X4 test, the difference is 33% while in Float x8, the difference is 34%. When compared to a DDR3 AMD 785G board, the results didn't differ too much too.
