DOOM3 benchmark of
ASRock M3A785GXH/128M AMD 785G+SB710 Mainboard
Benchmarks - DOOM3
With DOOM3 at 1024x768, we test if the game is playable at this resolution. To our surprise, we get 39.4 fps which might not be too playable but just pass the mark. With the GPU core increased to 980MHz, it scored 56.6 fps. The M3A785GMH/128M with GPU @ 900MHz scored 54.9fps just 1/2 a point behind DDR2 board running GPU @ 1GHz. With the 4th core enabled, the score shot to 57.6 fps which is 2 points higher than the other 2 boards.
