BIOS Screen shots 3 of ASRock
M3A785GXH/128M AMD 785G+SB710 Mainboard
Review
Bluetooth 13 Aug 2009
BIOS 3
The screen shots are taken with board installed with a AM3 X3 710
processor.
| DRAM voltage can be upped to
2.40v |
CAS Latency, trcd, tras, trp,
cmd rate can be set here |
| Sideport clock speed can be
adjusted beyond 1333Mhz to 1700MHz in the pull down menu. To check sideport
memory freq, you must AMD oc tool. |
On board GPU CLK can be
selected up to 2GHz |
| the mGPU voltage can be
increase for more stability. The maximum setting is 1.79v |
HT voltage can be set to 1.30,
1.35v or AUTO |
