DFI LAN Party 865PE Gallery (1) Oveclocker 18 Dec 2003
The Package
The Accessory Kit consists of the back plate, USB brackets, SATA cable, SATA power converter cable, IEEE 1394 bracket
The FrontX allows you to mix and match the connectors for front panel access.
Thinking of carrying your PC to your LAN Party, DFI packages it for you.
These Rounded cables that will glow under UV light is exceptionally nice.
