Gigabyte GV-R9500pro
Review (3)
Benchmarking We conduct the a number of tests on the setup with the following configuration : Test System: Test System:
CodeCreatures Benchmark Pro There is no doubt that when we run CodeCreatures benchmark, the R9500Pro performs very well. With only less than 1 frame difference from the GF4 Ti4600, it again shows that R9500pro card is indeed very close in performance to the Ti4600. A 3.9% difference between the two.
