EPoX
5LWA+ i925XE Mainboard Review 3/7
Benchmarks PCmark2004 PCmark2004 tests a number of important items in today's computing world. File Compression, Encryption, Decryption, Audio Conversion, Web Page Rendering, WMV Video Compression, DivX Video Compression, Physics Calculation and 3D, Graphics Memory etc. In this test, we look at the PCI-E results. When the board is OC to 3.7GHz, we see a substantial gain with a score of 5738. This is slightly lower when we run it at 18 x 201.8 with a score of 5467. This is 130 points higher than EPOX 5EPA+ running low latency ram (5336). As we can see, the DDR2-533 does not help a lot unless it runs in Sync mode at 266MHz.
