ASRock
4CoreDual-VSTA Review Benchmarks -
3DMark06
Bluetooth 19 Nov 2006
Benchmarks - 3Dmark2006
Futuremark's 3Dmark 2006 is ran with the ASUS
EN7900GT graphics card with Forceware 91.31. Below are the result break
down. As we have mentioned before, the VIA
PT880Ultra chipset only support a 4X PCIe lane. When we pair up this board
with the ASUS EN7900GT, we can immediately see the difference in performance
in 3D tests.
Another observation is that, when we use DDR or DDR2, the
difference is very little. Again, we see that DDR2 doesn't really bring much
increase in performance on this board.
With a check in the CPU score, we
can see that the Intel QX6700 score much better than the Intel X6800. A big
difference of 54% is registered.
For Gigabyte GA-965P-DQ6+QX6700,
Score is 5559, SM2: 2077, HDR/SM3: 2050, CPU Score : 3957
For Gigabyte GA-965P-DQ6+X6800, Score is 5323, SM2: 2086,
HDR/SM3: 2048, CPU Score : 2568
For 4CoreDual-VSTA+QX6700 (DDR2), Score is 5167, SM2: 1965, HDR/SM3: 1843, CPU
Score : 4010
For 4CoreDual-VSTA+QX6700 (DDR), Score is 5154, SM2: 1964, HDR/SM3:
1842, CPU Score : 3914
It can be seen that the benefit of
using DDR2 on this board is just a bit faster than DDR. In fact, if we were to
compare just the CPU score, the 4CoreDual-VSTA did well with a score of 4010.
