. ECS PN2-SLI2+ Review Benchmarks - Sandra 2007
Bluetooth 11 Dec 2006
Benchmarks
Sandra 07
The boards are first measured to ensure accuracy of CLK. In CPUZ test, we see that the CLK of the Gigabyte GA-965P-DQ6 is at 266.7 while the ASRock 4CoreDual-VSTA is at 266.1MHz.
In the tests to follow, the Gigabyte board is ran with 2GB of Corsair DDR2 running at CAS 5, 5-5-18 DDR2-800 mode while the ASRock 4CoreDual-VSTA will run in DDR mode with 1GB of Corsair memory at CAS 2, 2-2-5, 1T cmd and in DDR2 mode, it is run with the same pair of DDR2 modules (2GB) running at CAS 3, 3-3-8, 1T cmd DDR2-533.
The ECS PN2 SLI2+ runs at 266.7 which is just exactly at the same clk speed as the Gigabyte GA-965P-DQ6.
From the chart below, we can see that ECS PN2 SLI2+ seems to do better in terms of memory controller giving us a better score compared to the Gigabyte board based on i965P chipset. Will that translate to better scores in other tests? Lets press on.
