In this System clocks page, you can change
the CPU multiplier, the PCIe clk, the HT multiplier etc. |
FSB can be set from 400MHz to
2500MHz. That translates to base freq of 100MHz ~ 625MHz. Most 965P boards
has the range up to 600MHz while NV680 up it to 625MHz. |
Over here, you can set the Memory CLK. It
can range from DDR2-400 to DDR2-1400. This is where you will run your ram
async to your CPU. |
This is the overall settings on FSB and
Memory config. You can run CPU to Memory in a LInk (SYNC) or Unlinked
(ASYNC) mode. |
In the Memory timing adjustments, you can
select Expert mode. With it turned on, you can adjust the parameters to suit
your ram module esp for overclocking. |
One thing unique about this particular BIOS
is that you can turn off one of the cores of the CPU. it is said that it
will make o/c better. |
