Samsung Q1 UMPC Review 3/6
Bluetooth 28 Sep 2006
 Pricing from
various
vendors
Gallery 1 (Pricing)
Front : Surfing net using IE. On the left is a speaker and below it is a button that allows you to set the various resolutions. On the right , there is a short cursor key. Beneath it are two buttons, one is a return key and the other is for activating the side bar menu for changing brightness level, Enabled WIFI etc (as seen on the image above).
View of the unit from the top. On the left are three ducts for air flow. A on/off switch which allows power on the Q1 to normal Windows mode or multimedia mode. A CF card reader is on its right followed by a Ethernet Port.
On the other side of the Q1, we can see a 2 USB out, a speaker out, volume up/down button.
The back shows a stand. In fact there are two stands, It can be laid vertically or lie flat angled at around 30 deg to the horizontal. Below is is the Battery pack. A 2600mAH battery comes with the package which can last for around 2.5 hrs of usage on the average.
Power adaptor port for charging up the Q1. Another USB port and VGA out
Discuss >>>
