ASRock
4Core1333-FullHD ATi RS600/SB600 Mainboard Review Intro 1/5
Bluetooth 3 Jul 2007
of
ASRock ConRoe1333-DVI/H
Introduction
It has been
some time since ATi announced the RS600 chipset. Although it is a highly
anticipated chipset by many vendors, there were only a couple of brandsand are
not readily available in most markets. This probably because most are worried
support issues from AMD on a Intel chipset.
I was quite surprised by this move of ASRock as they took the
plunge. Seeing this it is an excellent chipset for Full HD support (up to 1080P)
for the Intel platform. It outshines the other RS600 boards with its
feature set offering support of 1394 and supporting the FSB1333 processors.
ASRock 4Core1333-FullHD supports all FSB1333/1066/800/533MHz
CPUs LGA 775 for Intel® Core™ 2 Quad / Core™ 2 Extreme / Core™ 2 Duo
/ Pentium® XE / Pentium® D / Pentium® Dual Core
/ Pentium® 4 / Celeron® / Celeron® D,
supporting Quad Core Kentsfield processors. Based on the ATI RS600/SB600
chipset, it supports Dual Channel DDRII800/667/533 with 4 DIMM slots, maximum
capacity up to 8GB. It comes with ATI™ X1250 graphics, DirectX 9.0, Max. shared
memory 512MB.
The board also comes with a PCIe x16 for external Graphics
card. Options in BIOS also allow overclocking of the CPU. For those who require
multiple displays, this board supports Dual VGA Output - Support DVI-D and D-Sub
ports by independent display controllers. For HD buffs, you can watch your BD or
HDDVD at 1080p with the HDCP through the DVI-D port (you would need a converter
to HDMI to connect to LCD TV).
On top of all these, the board supports PCIE Gigabit LAN 10/100/1000 Mb/s,
2 x IEEE 1394 ports (one port on back panel, one header on board). RS600
Chipset embedded HDMI Audio which supports HDMI signal through DVI-D port by
using DVI to HDMI adapter (not bundled).
The South bridge supports 4 x SATAII 3.0 Gb/s, support RAID (RAID 0, RAID 1,
RAID 0+1, JBOD and RAID 10) , NCQ, AHCI and "Hot Plug" functions, 7.1 CH Windows®
Vista™ Premium Level HD Audio (ALC888 Audio Codec).
Specs
| General |
| CPU |
- LGA 775 for Intel® Core™ 2 Quad
/ Core™ 2 Extreme / Core™ 2 Duo / Pentium® XE / Pentium®
D / Pentium® Dual Core / Pentium® 4 / Celeron®
/ Celeron® D, supporting Quad Core Kentsfield processors
- Compatible with all FSB1333*/1066/800/533MHz CPUs
- Supports EM64T CPU
| Chipset |
- Northbridge: ATI™ RS600
- Southbridge: ATI™ SB600 |
| Memory |
- 4 x DDRII DIMM slots
- Supports DDRII800/667/533
- Max. capacity: 8GB*
| BIOS |
- 4Mb AMI BIOS
- AMI Legal BIOS
- Supports "Plug and Play"
- Supports jumperfree
- SMBIOS 2.3.1 Support |
| Audio, Video and Networking |
| Graphics |
- Integrated ATI™ X1250 graphics
- DX9.0 VGA, Pixel Shader 2.0
- Max. shared memory 512MB
- Dual VGA Output: support DVI-D and D-Sub ports by independent display
controllers
- Supports HDCP function with DVI-D port
- Supports 1080p Blu-ray (BD) / HD-DVD playback with DVI-D port |
| Audio |
- 7.1 CH Windows® Vista™ Premium Level HD
- Chipset embedded HDMI Audio |
| LAN |
- PCIE x1 Gigabit LAN 10/100/1000 Mb/s
- Realtek RTL8111B
- Supports Wake-On-LAN |
| Expansion / Connectivity |
| Slots |
- 1 x PCI Express x16 slot
- 1 x PCI Express x1 slot
- 2 x PCI slots
- 1 x HDMR slot |
| Connector |
- 4 x SATAII 3.0 Gb/s connectors, support RAID (RAID 0,
RAID 1, RAID 0+1, JBOD and RAID 10), NCQ, AHCI and "Hot Plug" functions
- 1 x Floppy connector
- 1 x IR header
- 1 x COM port header
- 1 x IEEE 1394 header
- CPU/Chassis FAN connector
- 20 pin ATX power connector
- 4 pin 12V power connector
- CD in header
- Front panel audio connector
- 3 x USB 2.0 headers (support 6 USB 2.0 ports) |
| Rear Panel I/O |
ASRock DVI_1394 I/O
- 1 x PS/2 Mouse Port
- 1 x PS/2 Keyboard Port
- 1 x VGA/D-Sub Port
- 1 x VGA/DVI-D Port
- 1 x IEEE 1394 Port
- 1 x RJ-45 Port
Front Speaker / Microphone |
| Other Features / Miscellaneous |
Hybrid Booster |
- ASRock U-COP
| Support CD |
| Accessories |
- Floppy/ATA 133 cables
- 1 x COM port bracket |
| Hardware Monitor |
- CPU Temperature Sensing
- Chassis Temperature Sensing
- CPU Fan Tachometer
- Chassis Fan Tachometer
- CPU Quiet Fan
| Form Factor |
- Micro ATX Form Factor: 9.6-in x 9.6-in, 24.4 cm x 24.4
cm |
| OS |
XP 64-bit / Vista™ / Vista™ 64-bit compliant |
| Certifications |
- FCC, CE, WHQL |
