ASRock
4Core1333-eSATA2 Intel P31 Mainboard Review Intro 1/4
Bluetooth 6 Sept 2007
of
ASRock ConRoe1333-DVI/H
Introduction
ASRock
makes another first with its 4Core1333-eSATA2. This is probably the first
time that we see ASRock making a entry level board with a recently announced
chipset, the Intel P31.
ASRock 4Core1333-eSATA2 is based on the P31/G31+ICH7R
chipset. Unlike its brothers that are based on 945GC chipset, supports the full
range of Intel processors, they include LGA 775 for Intel® Core™ 2 Quad / Core™
2 Extreme / Core™ 2 Duo / Pentium® XE / Pentium® D / Pentium® Dual Core /
Pentium® 4 / Celeron® / Celeron® D, supporting Quad Core Kentsfield processors.
The board also supports Dual Channel DDRII800/667/533 x 4
DIMM slots, with max. capacity up to 4GB. It comes with 2 full length PCIe slots
that works in CrossFire mode using the additional AGI Express slot. The board
also comes with PCIE Gigabit LAN 10/100/1000 Mb/s, 2 x IEEE1394 ports (one port
on back panel, one header on board), 4 x Serial ATAII 3.0 Gb/s, support RAID
(RAID 0, RAID 1, RAID 10, RAID 5 and Intel® Matrix Storage), NCQ and AHCI
functions, 1 x eSerial ATAII 3.0 Gb/s (shared with 1 SATAII port), HDMI_SPDIF
header, providing SPDIF audio output to HDMI VGA card, allows the system to
connect HDMI Digital TV/projector/LCD devices.
7.1 CH Windows® Vista™ Premium Level HD Audio (ALC888 Audio Codec). It also has
some basic o/c options ready for the light overclocker.
Specs
| General |
| CPU |
- LGA 775 for Intel® Core™ 2 Quad
/ Core™ 2 Extreme / Core™ 2 Duo / Pentium® XE / Pentium®
D / Pentium® Dual Core / Pentium® 4 / Celeron®
- Compatible with all FSB1333/1066/800/533MHz CPUs
- Supports EM64T CPU |
| Chipset |
- Northbridge: Intel® P31/G31
- Southbridge: Intel® ICH7R |
| Memory |
- 4 x DDRII DIMM slots
- Supports DDRII800/667/533
- Max. capacity: 4GB*
| BIOS |
- 4Mb AMI BIOS
- AMI Legal BIOS
- Supports "Plug and Play"
- Supports jumperfree
- SMBIOS 2.3.1 Support |
| Audio, Video and Networking |
| Graphics |
- n/a |
| Audio |
- 7.1 CH Windows® Vista™ Premium Level HD
Audio (ALC888 Audio Codec) |
| LAN |
- PCIE x1 Gigabit LAN 10/100/1000 Mb/s
- Realtek RTL8111B / RTL8111C
- Supports Wake-On-LAN |
| Expansion / Connectivity |
| Slots |
- Supports ATI™ CrossFire™
- 1 x PCI Express x16 slot
- 1 x AGI Express slot (PCI Express x4)
- 1 x PCI Express x1 slot
- 3 x PCI slots |
| Connector |
- 4 x SATAII 3.0 Gb/s connectors, support RAID (RAID 0,
functions
- 1 x eSATAII 3.0 Gb/s connector (shared with 1 SATAII port)
- 1 x ATA100 IDE connector (supports 2 x IDE devices)
- 1 x Floppy connector
- 1 x DeskExpress Hot Plug Detection header
- 1x Game port header
- 1 x HDMI_SPDIF header
- 1 x IEEE 1394 header
- CPU/Chassis FAN connector
- 20 pin ATX power connector
- 4 pin 12V power connector
- SLI/XFire power connector
- CD in header
- Front panel audio connector
| Rear Panel I/O |
ASRock 1394_eSATAII I/O Plus
- 1 x PS/2 Mouse Port
- 1 x PS/2 Keyboard Port
- 1 x Serial Port: COM1
- 1 x eSATAII Port
- 1 x RJ-45 LAN Port
- 1 x IEEE 1394 Port
Front Speaker / Microphone |
| Other Features / Miscellaneous |
Hybrid Booster |
- ASRock U-COP
| Support CD |
| Accessories |
- Floppy/ATA 100 cables
- 2 x SATA data cables (optional)
- 1 x HDMI_SPDIF cable (optional) |
| Hardware Monitor |
- CPU Temperature Sensing
- Chassis Temperature Sensing
- CPU Fan Tachometer
- Chassis Fan Tachometer
- CPU Quiet Fan
| Form Factor |
- ATX Form Factor: 12.0-in x 9.0-in, 30.5 cm x 22.9 cm |
| OS |
XP 64-bit / Vista™ / Vista™ 64-bit compliant |
| Certifications |
- FCC, CE, WHQL |
