ASUS
P5E3 Deluxe WIFI/AP edition
Mainboard Review
- System Clock and Sandra XII
Bluetooth 27 Sep 2007
of
Gigabyte P35-DQ6
Benchmarks
CPU
FSB is still a valid and important
criteria when judging systems performance. We measured the
CPU FSB and
documented it as below. Both boards runs at 266.7MHz right on the dot.
The Gigabyte GA-P35T-DQ6 is paired up with 2GB of Samsung DDR3-1066 at CAS
7-7-7-20 while the GA-X38-DQ6 is with 2GB Corsair DDR2-1066 at CAS 5, 7-7-24.
The ASUS P5E3 Deluxe is paired up with 2GB of Samsung DDR3 memory running at CAS
7-7-7-20.
Sandra XII tests
From the chart, we can see that the ASUS P5E3
Deluxe do have a slight advantage with the slightly higher clk speed. It beats
the two Gigabyte boards in almost all categories of the Sandra XII tests.
Sandra XI |
Gigabyte GA-X38-DQ6 |
Gigabyte P35T-DQ6 |
ASUS P5E3 Deluxe WIFI-AP |
Memory Bandwidth |
5732/5723 |
5369/5407 |
5746/5720 |
Arithmetic - Drystone ALU |
27284 |
26501 |
27784 |
Artithmetic - Whetstone iSSE3 |
18626 |
18715 |
18888 |
Multimedia - Int x8 iSSE3 |
162254 |
160811 |
162593 |
Multimedia - Float x4 iSSE2 |
88341 |
87878 |
88520 |
Disk - Drive Index |
47 |
46 |
47 |
Disk - Random Access |
9 |
8 |
8 |
