System
Clock and SandraXI Gigabyte GA-G33M-DS2R Mainboard Review
Bluetooth 31 Jul 2007
of
Benchmarks
CPU
FSB is still a valid and important
criteria when judging systems performance. We measured the
CPU FSB and
documented it as below in 7 different boards
and noticed the CPU CLK. As it is a Conroe X6800, the default FSB is rated at
266MHz. As shown below, the three boards has set its default clk quite
differently. The ASRock Conroe1333-DVI/H runs at 267.9 while the Jetway 965GDAG
runs at 266.5, Gigabyte GA-945G-S3 at 268 and ASRock ConRoe945G-DVI at 265.8.
The ASRock 1333-D667 is similar to the Conroe945G-DVI and runs at a default of
265.8MHz. The Gigabyte GA-G33M-DS2R is at 266.7MHz.
In the following tests, other than
the ASRock 4Core1333-FullHD and Jetway 965GDAG are configured to run at
DDR2-800, the 4 other boards are configured to run at CAS 3, 3-3-8, 1T SYNC
DDR2-533 using a X6800 processor.
We made a check on the memory benchmarks and it
recorded at 5581/5600 with external graphics card 7900GT and 5535/5563 when the
embedded graphics is used.
