Gigabyte
P35C-DS3R DDR2/DDR3 (Intel P35) mainboard review -
Sandra 2007
Benchmarks Sandra 07
In the tests to follow, the Gigabyte P35-DQ6 board is run with 2GB of Corsair DDR2 running at CAS 5, 5-5-18 DDR2-800 mode while the ASRock 4CoreDual-VSTA will run in DDR mode with 1GB of Corsair memory at CAS 2, 2-2-5, 1T cmd and in DDR2 mode, it is run with the same pair of DDR2 modules (2GB) running at CAS 3, 3-3-8, 1T cmd DDR2-533. The ECS PN2 SLI2+ runs at 266.7 which is just exactly at the same clk speed as the Gigabyte GA-965P-DQ6. ASUS on the other hand has its 0505 bios tuned to 267.3MHz, that is a big higher than the rest of the boards in comparison. Will it give it a better edge during the benchmarks. The Gigabyte P35C-DS3R is run at DDR2-1066.
At DDR2-1066, we can see that the P35C-DS3R seems to be well tuned for better bandwidth. If we were to compare it with the P35-DQ6, we can notice the difference which amounts to almost 200 points. Would that translate to better results? Let's read on.
