Gigabyte
P35C-DS3R
(Intel P35) mainboard review - Introduction
Bluetooth 15 May 2007
of
AMD 690G boards
Introduction
Gigabyte
P35C-DS3R is Gigabyte's hybrid product based on the Intel P35/ICH9R chipset. The
brand new motherboard support for Intel upcoming 45nm Core 2 multi-core
processors. The P35C-DS3R supports support COMBO memory DIMM slots -both DDR2
and DDR3 for great flexibility. With Dual Channel DDR3 1066, outstanding system
performance can be attained as you can scale from DDR2-1066 to the future
DDR3-1600.
The board features Ultra Durable 2, a feature that
highlights the High Quality CPU Power design with Ferrite core chokes, Low RDS
(on) MOSFET and Solid Capacitors. These durable Capacitors take advantage of
Japanese manufactured solid capacitors for enhanced system durability.
Other features on this board include :
Features SATA 3Gb/s with RAID function
Audio controller from Realtek ALC 889A codec, featuring 106 dB Signal to Noise
ratio and supporting for both Blue-Ray and HD DVD Lose-less audio formats.
Satisfying customize demand, features a complete range of performance tuning
tools, such as C.I.A.2, BIOS Setting Recovery, and the latest Easy Tune5.
Certified for Microsoft VISTA Premium systems
Specs
Processor
Intel® Core™2 Quad/Core™2 Duo Processor
Support 1333/1066/800/533MHz FSB
Chipset
Intel® P35+ICH9R Express Chipset
Realtek 8111B GbE LAN
Realtek ALC889 8 channel HD audio codec
Memory
Supports DDR3 1066/800 memory
Supports DDR2 1066/800/667 memory
Dual Channel DDR3 supports by 2 DIMMs
Dual Channel DDR2 supports by 4 DIMMs
Expansion Slots
1 x PCI Express X16 slots
3 x PCI Express X1 slot
3 x PCI slots
Form Factor
ATX form factor (305 x 244mm)
Internal I/O Connectors
8 x Serial ATA 3Gb/s connectors
1 x UDMA ATA 133/100/66/33 connector
1 x FDD connector
4 x USB 2.0/1.1 connector (support 8 ports)
1 x Front Audio
1 x SPDIF_IN connector
3 x Cooling fan
Rear I/O Connectors
4 x USB 2.0/1.1
1 x RJ45
1 x Optical / Coaxial SPDIF_OUT
1 x LPT port
1 x COM port
6 audio jacks
PS/2 Keyboard/Mouse |
