. Gigabyte P35T-DQ6 (Intel P35) mainboard review - Sandra 2007
Bluetooth 31 May 2007
Benchmarks
Sandra XI
The boards are first measured to ensure accuracy of CLK. In CPUZ test, we see that the CLK of the Gigabyte GA-965P-DQ6 is at 266.7 while the ASRock 4CoreDual-VSTA is at 266.1MHz. The Gigabyte P35T-DQ6 and Gigabyte P35-DQ6 stays at the 266.7MHz mark.
In the tests to follow, the Gigabyte P35T-DQ6 runs Kington DDR3 modules at SPD CAS 7-7-7-20. The Gigabyte P35-DQ6 board is run with 2GB of Corsair DDR2 running at CAS 5, 5-5-18 DDR2-800 mode while the ASRock 4CoreDual-VSTA will run in DDR mode with 1GB of Corsair memory at CAS 2, 2-2-5, 1T cmd and in DDR2 mode, it is run with the same pair of DDR2 modules (2GB) running at CAS 3, 3-3-8, 1T cmd DDR2-533. The ECS PN2 SLI2+ runs at 266.7 which is just exactly at the same clk speed as the Gigabyte GA-965P-DQ6. ASUS on the other hand has its 0505 bios tuned to 267.3MHz, that is a big higher than the rest of the boards in comparison. Will it give it a better edge during the benchmarks.
From the chart below, we can see that the Gigabyte P35T-DQ6 scores 5716/5716 which is lower than its own sibling using DDR2-1066. Due to its clk at 266.7 as compared to the ASUS at 267.3, the memory bandwidth is slightly lower comared to 5790/5790.
Compared to the P35-DQ6, the DDR3 board seems to been optimised.
