There are 3 modes that the board can operate in. It can be
in plain UMA mode, SIDEPORT mode or UMA+SIDEPORT. UMA+SIDEPORT enable gives
the best performance for the integrated graphics. |
If SIDEPORT is chosen, the GFX Clk speed can be chosen.
The default is 400MHz |
If UMA+SIDEPORT is chosen, more options are available.
You can also override the default 500MHz GFX core by raising it to a a
maximum of 1023MHz. |
UMA Frame buffer size can be set to Auto, 32, 64, 128, 256
or 512MB. |
This is the default SIDEPORT graphics memory speed. |
GFX Engine Clk is default at 500MHz, it can be upped to
1023MHz. To run at higher GFX CLK, it is better to raise the NB voltage. |
