Call Of Juarez benchmarked on AMD Phenom II X4 940
running on ASRock AOD790GX/128M against QX9770 and Core i7 940
COJ Benchmarked and compared with QX9770 and Core i7 940
In this test, the 3GHz processor is paired up with a ATi Radeon HD 4850 graphics card. The system used 2x1GB DDR2-1066 memory running at CAS 5, 7-7-24, 2T. The BIOS used is 1.25. The processor runs at 15x200Mhz =3GHz. CoJ is tested on this benchmark and it scored 33.9fps on the average. On the ASRock P45XE-WifiN board it scored 34.1 fps while the Core i7 940 on GA-EX58-UD5 scored 33.9 fps just like the Phenom II X4 on ASRock AOD790GX/128M
