Crysis Demo benchmarked on AMD Phenom II X4 940
running on ASRock AOD790GX/128M against QX9770 and Core i7 940
Crysis Demo Benchmarked and compared with QX9770 and Core i7 940
In this test, the 3GHz processor is paired up with a ATi Radeon HD 4850 graphics card. The system used 2x1GB DDR2-1066 memory running at CAS 5, 7-7-24, 2T. The BIOS used is 1.25. The processor runs at 15x200Mhz =3GHz. With all settings to High and resolution set to 1600x1200, the test is run with no AA. The test result in a benchmark score of 31.235 fps. It is pleasing to see that both QX9770 scored only 30.09 fps while the Core i7 scored 30.39 fps in this test. The Phenom II X4 isn't that bad after all.
