Lost Planet benchmarked on AMD Phenom II X4 940
running on ASRock AOD790GX/128M against QX9770 and Core i7 940
Lost Planet Benchmarked and compared with QX9770 and Core i7 940
In this test, the 3GHz processor is paired up with a ATi Radeon HD 4850 graphics card. The system used 2x1GB DDR2-1066 memory running at CAS 5, 7-7-24, 2T. The BIOS used is 1.25. The processor runs at 15x200Mhz =3GHz. AMD Phenom II X4 scored 51 for Snow benchmark and 70 for Cave Benchmark. On the QX9770 running on P45XE-WiFi-N, it only scored Snow 49 and Cave 67. Looks like the Phenom II X4 940 is a winner in this test. On the other hand, the Intel Core i7 940 scored Snow 51 and Cave 68, just 2 fps slower than the Phenom II X4.
