Review : Introduction
to ASRock K10N750SLI-WiFi NVIDIA nForce 750a mainboard (MCP72) mainboard
Introduction
ASRock introduces the first nForce 750A SLI mainboard. This mainboard supports
the
Socket AM2+ / AM2 processors: AMD PhenomTM FX / Phenom / Athlon 64 FX / Athlon
64 X2 Dual-Core / Athlon X2 Dual-Core / Athlon 64 / Sempron processor. It
features alll Solid Capacitor design and supoprt Dual Channel DDR2 1066 with
AM2+ CPU, and DDR2 800/667 with AM2 CPU, with 4 DIMM slots up to a maximum
capacity up to 8GB.
This board
comes with
2 x PCI Express 2.0 x16 slots (green @ x16 mode, blue @ x8 mode). It can run in
SLI mode in a Dual PCIe x8 configuration. Alternatively, it can run with one
8500 or below card to run in Hybrid SLI mode with the inbuilt IGP (which has no
independent output).
Other features on this board includes 6 x Serial ATAII 3.0 Gb/s connectors,
support RAID (RAID 0, 1, RAID 0+1, RAID 5, JBOD), NCQ, AHCI and Hot Plug
functions, - 1 x eSATAII 3.0 Gb/s connector, Gigabit LAN 10/100/1000 Mb/s, 2 x
IEEE 1394 headers (one port on back panel, one header on board). In addition, it
has a 7.1 CH Windows® Vista™ Premium Level HD Audio with Content Protection,
supports DAC with 110dB dynamic range (ALC890 Audio Codec), DTS (Digital Theater
Systems).
In terms of expansion, the board comes
with 1 x WiFi/E header. The backplate also has 1 x Coaxial SPDIF Out Port,
1 x Optical SPDIF Out Port, 1 x eSATAII port, 1 x RJ-45 LAN Port with LED, 1 x
IEEE 1394 port, 6 x USB 2.0 Ports.
For those who wants to o/c the board, there is the ASRock OC Tuner. With the
software IES ( Intelligent Energy Saver), you can also see the power savings in
realtime.
IES is first implemented on ASRock K10N750SLI-WiFi. It is based on AMD PSI
(Power State Indicator) spec, which is a function for AM2+ platform to improve
energy efficiency by disabling extra phases when CPU is at light loading. The
exclusively designed Intelligent Energy Saver can effectively increase Voltage
Regulator Efficiency by 16% and decrease its Voltage Regulator power consumption
by 48% without reducing CPU performance and reliability.
