Review : Introduction
to ASRock K10N78hSLI-WiFi NVIDIA GeForce 8200 (MCP78) mainboard
Introduction
ASRock introduces the K10N78hSLI-WIFI based on the GF8200. This is the first
time a manufacturer uses a GF8200 as a discrete chipset and enable it with
hybrid SLI. As you are aware that GF8200 comes with embedded IGP, ASRock did not
include any HDMI nor D-SUB connectors. Instead, the board will only function
with display if you pair it up with an external graphics card.
For those who wants to o/c the board, there is the ASRock OC Tuner. With the
software IES ( Intelligent Energy Saver), you can also see the power savings in
realtime.
IES is also implemented on this board. It is based on AMD PSI
(Power State Indicator) spec, which is a function for AM2+ platform to improve
energy efficiency by disabling extra phases when CPU is at light loading. The
exclusively designed Intelligent Energy Saver can effectively increase Voltage
Regulator Efficiency by 16% and decrease its Voltage Regulator power consumption
by 48% without reducing CPU performance and reliability.
This board suports the AM2/AM2+ processors with
DDR2 800/667/533 with AM2 CPU, with 4 DIMM slots, maximum capacity up to
8GB. It supports NVIDIA® Hybrid SLI™ GeForce® Boost feature. The board
coems with 1 x PCI Express 2.0 x16 slot (green @ x16 mode), 6 x Serial ATAII 3.0
Gb/s connectors, support RAID (RAID 0, RAID 1, RAID 0+1, RAID 5, JBOD), NCQ,
AHCI and Hot Plug functions. It also has 1 x eSATAII 3.0 Gb/s connector,
supports Gigabit LAN 10/100/1000 Mb/s, 2 x IEEE1394 ports (one port on
back panel, one header on board) and 1 x WiFi/E header. Audio is a 7.1 CH
Windows® Vista™ Premium Level HD Audio with Content Protection, supports DAC
with 110dB dynamic range (ALC890 Audio Codec).
* Windows® Vista™ Premium 2007 Logo Ready
