Review Conclusion of ASRock P45R2000-WiFi Intel P45 chipset mainboard review
Bluetooth 21 Jul 2008
ASRock P45R2000-WiFi is an interesting board we tested based on the Intel P45+ICH10R chipsets. In our test, we were wondering if we were really testing an ASRock board. This board doesn't look like the familiar ASRock boards we have tested in the past. It has so many features on board that makes it a top notch board in the league of the 1st tier board makers.
Features like Dual GbE, Realtek ALC890B audio, 1394, WiFi/AP, eSATA. These are some of the features that you would see on the expensive ASUS boards are now available on the P45R2000-WiFi. One thing that is probably lacking from this board is those energy saving features like ASUS's EPU. If not, judging by the feature set and the functionality of this board, it could well be as good or even better than the 1st tier boards out there.
In terms of Performance, this board performs pretty well when we pair it up with DDR3 modules. As the board supports up to DDR3-1333. The QX9770 (1600FSB) cpu actually runs the memory at a 2:3 ratio. Thus the modules actually clock at DDR2-1200 instead of 1333. It uses ram timng of C7 -7--7-20-2T.
In terms of overclocking, the BIOS included a large range of FSB and voltage options available. You can see the BIOS options here. In our o/c test, we used a E6550 processor that clocks at 7x333. We first booted at 500MHz x6, we later move it up to 540MHz x6 in BIOS. The system works at that speed. We finally move up to 560x6 using ASRock OC Tuner. 560MHz is also the limit of our E6550. If paired with a E8400, I suppose it should be able to go higher. The voltages used are shown below.
In conclusion, this board serves the needs for those who require P45 performance and CrossFire in future. It has a lot more than the basic features that most users would require and priced at an affordable price against the competitor products. There are also variations of this board with slightly different model names.
BIOS used : P1.20. For beta bios, please visit http://my.ocworkbench.com/bbs
  • Wide range of FSB
  • 2 eSATA
  • 2 GbE
  • Dual memory slots
  • ASRock OC Tuner
  • WiFi
  • no debug LED
 Category
Score
 Performance
10 / 10
 Features
10 / 10
 Ease Of Installation
10 / 10
 Overclocking Features
9 / 10
 Documentation
8 / 10
 Packaging
9 / 10
 Cost / Performance
9 / 10
 Overall Rating :
9.28 / 10
Related Reviews 1
Related Reviews 2
Related Reviews
3
