ASRock
X48TurboTwins-WiFi Intel X48 chipset mainboard review - Introduction
Bluetooth 15 Jun 2008
Introduction
ASRock has so far released a number of high end boards which stunned the
industry. Today, we are going to take a look at another high end board
from ASRock - the X48TurboTwins-WiFi.
As the model name implies, this board is based on the Intel X48 + ICH9R chipset.
With it's dual memory TWIN support, it allows users to run the board using
either DDR2 or DDR3. It supports upports Dual Channel DDR3 1600 with max.
capacity up to 8GB and Dual Channel DDR2 1066 with max. capacity up to 4GB.
The board also support 2 PCI Express 2.0 x8 slot for CrossFire or Single PCI
Express 2.0 slot for PCI Express x16 speed. Other than that, it comes with 1 x
ASRock WiFi-802.11g Module and 1 x Antenna to convert your board into a Access
Point. Other features include
PCIE Gigabit LAN 10/100/1000 Mb/s, 2 x IEEE1394 ports (one port on back panel,
one header on board), 6 x Serial ATAII 3.0 Gb/s connectors, support RAID (RAID
0, RAID 1, RAID 10, RAID 5 and Intel® Matrix Storage), NCQ, AHCI and Hot Plug
functions. 2 x eSerial ATAII 3.0 Gb/s connectors, 7.1 CH Windows® Vista™ Premium
Level HD Audio with Content Protection, supports DAC with 110dB dynamic range
(ALC890 Audio Codec), DTS (Digital Theater Systems) support.
The board's BIOS also support I.O.T, allowing you to overclock with ease. There
are also a large amt. of voltage options and large range of Frequencies (200 ~
800) etc for you to overclock. If it is not enough, you can use the ASRock OC
tuner to achieve a higher overclock within Windows.
Specs
General CPU - LGA 775 for Intel® Core™ 2 Extreme /
Core™ 2 Quad / Core™ 2 Duo / Pentium® Dual Core / Celeron®,
supporting Penryn Quad Core Yorkfield and Dual Core Wolfdale processors
- Supports FSB1600/1333/1066/800MHz CPUs
- Supports EM64T CPU Chipset - Northbridge: Intel® X48
- Southbridge: Intel® ICH9R Memory - Dual Channel DDR3/DDR2*
memory technology
- 4 x DDR3 DIMM slots
- Supports DDR3 1600/1333/1066/800 non-ECC, un-buffered memory
- Max. capacity of system memory: 8GB**
- 2 x DDR2 DIMM slots
- Supports DDR2 1066/800/667 non-ECC, un-buffered memory
- Max. capacity of system memory: 4GB**
BIOS - 8Mb AMI BIOS
- AMI Legal BIOS
- Supports "Plug and Play"
- Supports jumperfree
- SMBIOS 2.3.1 Support
- CPU, DRAM, NB, SB,VTT Voltage Multi-adjustment
- Supports I. O. T. (Intelligent Overclocking Technology) Audio, Video and
Networking Graphics - n/a Audio - 7.1 CH Windows®
Vista™ Premium Level HD Audio with Content Protection
- DAC with 110dB dynamic range (ALC890 Audio Codec)
- DTS (Digital Theater Systems) support LAN - PCIE x1 Gigabit LAN
10/100/1000 Mb/s
- Realtek RTL8111C
- Supports Wake-On-LAN Wireless LAN ASRock WiFi-802.11g module
- 54Mbps IEEE 802.11g / 11Mbps IEEE 802.11b
- Supports Software Access Point mode (AP mode) and Station mode (Infrastructure
mode and Ad-hoc mode) Expansion / Connectivity Slots - Supports
ATI™ CrossFire™
- 2 x PCI Express x16 slots (green @ x16 mode)
- 1 x PCI Express x1 slot
- 3 x PCI slots Connector - 6 x SATAII 3.0 Gb/s connectors, support RAID
(RAID 0, RAID 1, RAID 10, RAID 5 and Intel® Matrix Storage), NCQ,
AHCI and Hot Plug functions
- 2 x eSATAII 3.0 Gb/s connectors (shared with 2 SATAII ports)
- 1 x Floppy connector
- 1 x DeskExpress Hot Plug Detection header
- 1 x HDMI_SPDIF header
- 1 x IEEE 1394 header
- CPU/Chassis FAN connector
- 24 pin ATX power connector
- 8 pin 12V power connector
- CD in header
- Front panel audio connector
- 2 x USB 2.0 headers (support 4 USB 2.0 ports)
- 1 x WiFi header Rear Panel I/O ASRock 1394_SPDIF I/O Plus
- 1 x PS/2 Mouse Port
- 1 x PS/2 Keyboard Port
- 1 x Coaxial SPDIF Out Port
- 1 x Optical SPDIF Out Port
- 6 x Ready-to-Use USB 2.0 Ports
- 2 x eSATAII Ports
- 1 x RJ-45 LAN Port with LED (ACT/LINK LED and SPEED LED)
- 1 x IEEE 1394 Port
- HD Audio Jack: Side Speaker / Rear Speaker / Central / Bass / Line in / Front
Speaker / Microphone Other Features / Miscellaneous Unique Feature
- ASRock OC Tuner
- Hybrid Booster:
- ASRock U-COP
- Boot Failure Guard (B.F.G.) Support CD
- Drivers, Utilities, AntiVirus Software (Trial Version) Accessories - 1
x ASRock WiFi-802.11g Module
- 1 x Antenna
- 1 x WiFi Bracket
- Floppy/ATA 133 Cables
- 4 x SATA Data Cables (Optional)
- 1 x SATA 1 to 1 Power Cable (Optional)
- 1 x HDMI_SPDIF Cable (Optional) Hardware Monitor - CPU Temperature
Sensing
- Chassis Temperature Sensing
- CPU Fan Tachometer
- Chassis Fan Tachometer
- CPU Quiet Fan
- Voltage Monitoring: +12V, +5V, +3.3V, CPU Vcore Form Factor - ATX Form
Factor: 12.0-in x 9.6-in, 30.5 cm x 24.4 cm
- All Solid Capacitor
design OS - Microsoft® Windows® 2000 / XP / XP
64-bit / Vista™ / Vista™ 64-bit compliant Certifications - FCC, CE, WHQL
