Review : ASUS Eee PC
900 based Intel Mobile Celeron 900MHz with 8.9" Screen
Connectors on the Eee PC 900
Although it has a small footprint, the ASUS EeePC is pretty
standard for it's expansion capabilities. On the side of the unit, you have
direct access to the 1 USB 2.0, LAN port on the left of the portion. On the
right hand side, you have 2 more USB 2.0 ports, 1 MMC/SD slot and 1 D-SUB
connector for output to LCD TV or monitor. As this is a portable mini notebook, multimedia functions is
a must. ASUS EeePC 900 included a 1.3 mega pixel web cam. There is also a
earphone jack and mic for video conferencing use.
