ASUS Striker II
Extreme nForce 790i Ultra SLI mainboard review
- BIOS Screen shots
Bluetooth 1 Apr 2008
BIOS 2
QX9770.
| Memory level can be set to run
in ASync mode to the CPU CLK. Here are three options available when the
board is installed with a QX9770 |
AI Overclocking can be set to
let it auto o/c the board. In our case, we set it to manual. |
| CPU MUltiplier |
MEM (DDR) can be to run in
ASync mode to the CPU CLK. The range is 800 ~ 3000MHz. Likewise the FSB can
be set from 800 ~ 3000MHz too (that is from 200MHz ~ 750MHz) |
| DDR3 ram timing adjustments |
CPU voltage can be raised to a
maximum of 2.40v |
