Review Conclusion
of
Biostar TA790GX A2+ AMD
790GX+SB750 mainboard Conclusion
Biostar TA790GX A2+ ver 5 is our 2nd board that came to our testing labs some time ago. This AMD 790GX+SB750 board has almost all the features that you need, supported by the AMD SB750 south bridge. As you are probably aware, the AMD 790GX supports not only Sideport for better IGP performance, it also supports Hybrid CrossFire and also CrossFireX (with dual 8x slots). Thus, this board is a master of all. Features-wise, the board is equipped with a 2 PCIe x16 slot which can work in a single PCIe x16 or Dual PCIe x8 in CrossFire mode. There are also 6 SATA II ports supporting raid 0,1,5,0+1. There is also GbE, HDA, HDMI, USB. The board does support sideport memory with a 64MB chip This is probably the reason why you see a slightly lower 3D performance when the board is compared to a 128M sideport memory board. As for CPU overclocking, the BIOS comes with a wide
range of options including memory timing, voltages, wide range of HTT etc. See gallery for more information.
You could also use the supplied BIOSTAR o/c tool in the CDROM to overclock the
board. In addition, on the SB750 (SB) of the board is the
Embedded Controller for AMD OverDrive- Advanced Clock Calibration. With that,
we can run AMD Overdrive to overclock the CPU cores by adding a 4% increase in
all the 4 cores through this option below.
