DOOM3 benchmark of
ECS A780GM-A Ultra AMD
780G+SB750 Mainboard Review
Bluetooth 2 Dec 2008
Benchmarks -
DOOM3
With DOOM3, this benchmark is run at 1600x1200 Hi Quality. With UMA only, the
ECS A780GM-A Ultra scored 17 fps and when overclcok scored 20.7 fps. On
theASRock board scored 19.4 fps almost on par with the two other boards. With Sideport
enabled, it scored 23.1 vs 21 (Biostar) and 23.3 (Gigabyte). When o/c and
sideport enabled, the board score gets a boost to 24.4 fps while the Biostar get
22.6. The Gigabyte does better at 26.2 fps.
Again, we can see that the AMD 780G is disadvantaged because of it's lower GPU
Clk. When o/c it score 20.7,which is way better than the AMD 790GX boards with
Side port disabled.
*DOOM 3 tested at 1600x1200 Hi Quality
