F.E.A.R benchmark of ECS A780GM-A Ultra AMD
780G+SB750 Mainboard Review
Benchmarks - F.E.A.R In the F.E.A.R Multiplayer DEMO benchmark, it is tested in MAX/High Setting for CPU/GPU. The ECS A780GM-A Ultra scored 23 fps and 26 fps when overcloked. As we can see from the chart, the A780GM-A matches the 790GX (with Sideport disabled @700MHZ) when it is o/c to 1GHz. All 3 boards ASRock AOD790GX/128M, BIOSTAR TA790GX A2+ and Gigabyte GA-MA790GP-DS4H scored 26fps with UMA enabled. With Sideport enabled, both ASRock and Gigabyte gets a boost of 4 fps to 30 fps while Biostar runs at 28 fps. The noticeable difference is when it is overclocked at 1GHz, The ASRock scored 31 fps while the Gigabyte scored 33 fps. 2 fps slower than the DDR3 sideport version of 790GX.
