ECS P45T-A Intel P45 chipset mainboard review - SiSoft
Sandra XII Benchmarks
In this test, we checked out the difference between the 4 boards, the ECS P45T-A, Gigabyte EP45 Extreme, ASRock P43R1600Twins-WiFi and the ASRock X48TurboTwins-WiFi. The boards are running the ATi Radeon HD 4850 graphics card with an Intel QX9770 processor. Using CPU-Z, we checked the CPU Clk, the ECS P45T-A runs at 400.0Mhz while the Gigabyte EP45 Extreme was clocking at 400.1MHz, ASRock P43RTwins-WiFi is slightly o/c at 400.3MHz and the ASRock X48TurboTwins-WiFi clocks at 400.0. ECS P45T-A, Gigabyte GA-EP45 Extreme and ASRock P43R1600Twins-WiFi runs a pair of Kingston DDR2-1100 module at DDR2-1066 @ C5-7-7-24-2T while the X48TurboTwins-WiFi runs a pair of Kingston DDR3-1800 module at DDR3-1600 @ C7-7-24-2T. We used the BIOS dated 0619. As P45 doesn't officially support FSB1600, when we set the memory to run at DDR2-800, it actually runs the memory at DDR2-960 instead of DDR2-1066. Surprisingly, this did not slow the system down by a lot. From the score chart, we can see that other than the memory bandwidth is lower, the arithmetic scores well but loses a bit in the multimedia tests.
