Review Conclusion
of
ECS P45T-A Intel P45 chipset mainboard review Conclusion
ECS Black label series is ECS's mid range series that targets price/performance built with quality. As we have seen so far, the numbers tells us that the ECS P45T-A isn't that bad after all. In some areas, the numbers are far better than the more expensive copper heatpipe boards. Features wise, the ECS P45T-A is basically just a
board that conforms too much to the specs. For example, some boards support
DDR2-1200 but ECS only supports DDR2-800. You also don't get fanciful names for
power savings features which adds up to the cost. What I liked most on this
board is the external SATA and the power on /off and reset switches. ECS could
have put in a DEBUG LED and CLR CMOS. That would make it better.
In conclusion, this board serves the needs for those who require P45 performance and CrossFire in future. It has all the basic features that most users would require and priced at an affordable price. BIOS used : 0619. For beta bios, please visit http://my.ocworkbench.com/bbs
