BIOS Screen shots 2 of
Gigabyte GA-MA790GP-DS4H AMD 790GX+SB750 mainboard
Bluetooth 4 Aug 2008
BIOS 2
The screen shots are taken with board installed with a Phenom 9550.
| CPU freq can be set from 200
to 500MHz |
PCIe clock can be set from 100
to 200MHz. |
| VGA core is selectable from
200 to 2000MHz. The default is 700MHz (but on F1 bios is 500MHz). |
The Memory clock can be set
for the integrated GPU. At 5.33x, it will run at 533MHz. |
| Memory timings can be manualy
adjusted. On the screen shows that SPD and Auto settings. |
South bridge voltage can be
bumped up by +0.3v |
