Gigabyte GA-X48T-DQ6
Intel X48 chipset mainboard review - Introduction
Introduction
Gigabyte GA-X48T-DQ6 is the next generation of
motherboard that improves on the former X38 design. With the new Intel X48
chipset, it officially supports the Intel® Core 2™multi-core and upcoming 45nm
processors with 1600 MHz FSB Yorkfield and Wolfdale processors. Not only that,
it also supports DDR3 1900 memory with Intel® XMP technology enables new
levels of memory performance. This new board features Ultra Durable 2–Dynamic
Energy Saver. This unique multi-gear power phase design allows for the most
efficient switching of power phases depending on CPU workload. It also features
Ultra Durable 2-Advanced Power designHigh quality components design with Ferrite
Core Chokes, Lower RDS (on) MOSFETsand Lower ESR Solid Capacitors. Unique design
with virtual 12 phases in CPU power module, 2 phases in north bridge and 2
phases in DIMM. The board also comes with Unique thermal design featuring all
copper Silent-Pipe and Crazy Cool and Japanese manufactured SMD All Solid
Capacitor motherboard design. The board also comes with plenty of expansion
options. It supports ATI CrossFireX™with Dual PCI-E 2.0 x16 graphics for extreme
gaming performance. It also features SATA 3Gb/s with Quad eSATA2 interface, ALC
889Awith DTS Connect enables high quality Full Rate Lossless Audio and support
for both Blu-ray and HD DVD. There is also Quad BIOS for an extended level of
protection, Quad-Triple Phase Power Designfor ultimate system stability. There
is a Dual Gigabit Ethernet LAN with Teaming functionality. Accessories
